B
Bodd
Would anyone know if some TRV's are directional.?
Do any manufactures advise they have to go on the Flow?
Bod
Bod
Is 'Ornate' a description or a Brand name?Fitted new Ornate
If a description, which brand are they?
Did you balance the system?
And the LS valve leaks!But they are an expensive Victorian style TRV and Lock shield set.
That's helpful! And you've thrown the MI's away?There are no arrows
And the LS valve leaks!But they are an expensive Victorian style TRV and Lock shield set.![]()
That's helpful! And you've thrown the MI's away?There are no arrows![]()
Can you find out who actually makes the valves, so you can speak to them or the importers?
The noise, caused by the valve 'bouncing' as it tries to close, is due to too high a pressure difference across the valve.
Correct balancing will reduce the pressure difference.
Read How to balance a CH system
Ideally, yes; but it depends on how the rads have been sized. Balancing for a 20C drop (75/55) will reduce the output by about 15%, which may not be significant if the rads are already 20% larger than required.I tend to fit Worcesters I aim to go for 20 degrees difference on the flow/ return on the boiler. But should I be looking for that on each individual radiator as well?
I don't think this can be classified as a 'gas-related question', so it can be discussed on an open forum. Tony (Agile) will soon put me right.I Realize I should be doing this in combustion chamber
