http://media.diynot.com/99000_98749_61336_17149242_thumb.jpg
Washers needed to change a wax stat
in situ are: 3,5,&6 are included with the wax stat. 2x24 (Part No. 980223) thats it.
Turn off power switch, cold and heating isolation valves.
Drain boiler cold/hot circuits and primary circuit.
Undo the two cold connection nuts on the base of the flow switch.
Use a long flat blade screwdriver from underneath the cold water housing on the flow switch and remove the three screws. Be ready to catch a bit of water.
Remove the wax stat from the housing (a sharp tap through the base with a screwdriver will dislodge it).
Make sure the small rubber washer isn't stuck up in the main flow switch body and then insert the new wax stat in the cold connection base using the 3 new rubber washers. Refit to main flow switch body with 3 screws. Look for red stamp on body to ensure correct orientation or mark before disassembly.
Connect the cold tubes to the base using new washers as above. Turn on cold and check for leaks. run hot tap to purge air.
Adjust 7mm nut on flow switch spindle so plate just sits against right hand microswitch (important).
Refill primary circuit, vent, turn mains switch on re-vent and test.
Failing that call Bunnyman lol!
