I am thinking of submitting one - anyone know what exactly is required?
You write to the council telling them what you propose, including the distance out you are proposing to build, the maximum height, and the height of the eaves. You also have to send them a "plan" identifying the property and the extension.
The council will write to your immediate neighbours and give them 21 days to comment.
If they object, the council will almost certainly not give you approval and will suggest a planning application.
If the neighbours don't object, you can get stuck in.
What a ridiculous system.
Thanks - What format are these plans in exactly? Do they have to be elevation and side plans?
There is no definition given in the legislation, but it does NOT include elevations.
There is no mention of scale, or that the drawing must be done on CAD or anything, only that it should be sufficient to identify the site and extension.
In short, if you just submit a rough sketch with simple, and unsatisfactory information to assess the entire application - then it will be refused... because you will not have demonstrated that your proposal meets with the permitted development rights.
