I have been tasked with the re-wire a large property local to me. Seeing as it's a few years since i passed my 16th Edition and Part P and completed my last re-wire I need some help with the current state of play.
(I am not registered with ELECSA or similar, I will have to get my tester calibrated forthwith!)
From memory I have to submit a plan to my local council building control, complete the work and submit test results to them. Any change to this?
It's currently a PME system to a cellar located consumer unit. Customer requirements are for 2 further consumer units on higher floors of the property with separate meters to each unit so that lodgers can be charged an appropriate fee for their electricity usage (but she wants just a single bill to the property based on the main meter in the cellar) and so that any fault on either 'secondary' consumer unit does not trip her 'primary' RCD. Do I run 16mm singles from a non-RCD protected breaker in the main unit to feed RCD protected secondary consumer units? Or put 2 units in the cellar, one just to feed the secondary units?
Any product suggestions for the 'secondary' unit metering?
Any help appreciated, thanks.
