Very good point - when I saw the SCR with its gate connected to the output of the IC, I subconsciously assumed that it was 'doing the obvious thing' and didn't look carefully enough at the diagram! In fact, not only is there no obvious connection to anything which operates the contacts, but it looks as if the only thing which will happen when the SCR fires is that the power supplied to the electronics will (if the polarity is correct) fall to the Vf of the SCR!I can see the SCR that fires and the contacts that open circuit the Live and Neutral but I cannot see the symbol for a coil or other means of operating the contacts.
I think I need to ignore this 'Application note' and go back and look at the actual animal again. Unfortunately, some of the components of that RCD got largely destroyed by the 'incident', but I'll do my best!
