Are you talking about making the frame temporarily secure, or a more permanent measure?
If its the former, close the door and fix timber battens across the frame from the inside. If its the latter then the split can be glued and cramped and any holes filled with dowel - and then its probably best to shift the hinge position a little. It really depends on how bad the damage is!
John
