I had a job to look at today where someone had set fire to some rubbish in an intake cupboard. Uk power networks have dug up some of the road and disconnected the incoming tncs supply. They will not run a new supply until a new armoured cable has been installed and tested. I was thinking of installing a 60amp wylex isolator supplying 16mm 3 core swa. The run is about 15m long. Is there any problem with this or will the swa need to 25mm?
