Help - layers of trouble
13 Aug 2013
Yorkshire
Hi please can anyone help - I'm several layers into a frustrating problem and stuck now - its a long story I'm afraid:
Painting bathroom - over existing silk emulsion on walls.
Mistake 1 I didn't sand down existing paint
Mistake 2 didn't use a bathroom specific silk used ( not waterproof)
2 coats later, Paint discolours when getting wet, leaving permanent marks.
Also chips off too easily
I covered it with 1:1 PVA solution to seal it as recommended by 2 professionals
Then painted with bathroom specific silk with a paint pad
Now When painting new colour, wet paint lifts off previous coats, and/or crackles underneath.
Fed up - should I completely sand down and start again or is there a cheat?
You can't successfully paint over PVA, so I don't know who told you you could. If there is a primer that will seal it, then maybe someone with more experience than I will tell you what it is. I wouldn't relish the thought of sanding it off but you might have to.
If it helps, I have flat matt emulsion on my bathroom walls; I do have to wipe streaks off it periodically but the paint stays on the wall.
Cheers
Richard
