Valve on pipe too low to reach rad
18 Jul 2013
Hi all,
I'm fitting a new rad in a room and long story short the valve on one side isn't reaching the corresponding adaptor. The rad is level according to my spirit level - one side matches up to the valve on the feed pipe fine, but for some reason the return pipe is a bit on the short side and the valve can't get to the adaptor. Pic below. There's a good 10mm difference. I can't move the brackets on the wall any further down without having to re-drill the holes.
http://3.bp.blogspot.com/-3ckAEsxBqnI/UhARGLNtthI/AAAAAAAABa4/2nOZgqvA7zU/s1600/IMAG0758.jpg
Is there any way of extending the pipe up a bit? It doesn't move from its current position - there's no play in it vertically.
Many thanks.
to elaborate on what petit said
cut the pipe lower down and then extend it to where you need it
as take the other side fits
Id love to hear the long story.
Assumptions are the mother of all fookups ;)
Assuming one of the parts of the long story are a figment of my imagination. Remove the rad. Cut the other pipe to match your short one and rehang.
This time double check before drilling.
Perhaps the pipes dropped in the floor a tad and needs pulling back up :wink:
Thanks - just with a normal straight solder-on coupling?
See I thought that, it seems odd for the pipes to not match any more but maybe the old rad wasn't level. Anyway I did try pulling it up but like I say it doesn't budge. Thanks anyway though!
