Just had electrician fit me a new CU, during the fitting he informed me that second ring main has no continuity on the live side so he has fitted a 16amp mcb rather than a 32amp on this ring. I have since looked at this myself, taking all the face plates off and making sure that there's no loose or trapped wires on the insulation and all okay, I then checked the lives at the CU for continuity and all okay phase showing 0.05 ohms resistence.
I then connected phase 1 to neutral 2 and phase 2 to neutral 1 and checked the readings on each socket outlet on that ring, all gave a reading of 0.07, so i'm assuming no bridge across this ring.
Is there anything I have missed or as the electrician made a mistake.
Many thanks.
Many thanks.
