Anybody who chooses to imbue any word with an unofficial definition only has themselves to blame if they don't like what they have chosen.
I would never speak of ‘Simples’ and the MH problem in the same breath...that Monty Hall Problem got me.
(I did not see the explanation of the answer, just the what the producers said after it had run a while and the results were found to be similar to their calculations). ... I eventually gave up to it because I was thinking a 1 in 3 chance becomes a 1 in two chance (a 50% increase on a winning outcome) . ... Two weeks later, having not thought about it, I looked in the mirror, and Eureka - the answer came in a blinding flash out of the blue- simples once you twig it.
For the lazy amongst thsoe who can't be bothered to do it in their heads, try the following (in BASIC, since that's probably the most universally-undesrood language, but it can easily be adapted to ansy other language. Decoded answer in X$:Lbh fgnegrq jvgu guerr qbbef, oruvaq gurz jrer gjb tbngf naq bar pne. Lbh unir cvpxrq bar, naq gura gur ubfg, JUB XABJF JURER GUR PNE VF, bcraf nabgure gb erirny n tbng. Lbh ner evtug gb fjvgpu vs lbh bevtvanyyl cvpxrq bar bs gur gjb qbbef jvgu n tbng. Cebonovyvgl gjb guveqf. Lbh ner jebat gb fjvgpu vs lbh bevtvanyyl cvpxrq gur qbbe jvgu gur pne. Cebonovyvgl bar guveq. Fvzcyrf.
(I'm assuming that not many people can do ROT13 in their heads).
What you have written (in code) is surely just a statement of the obvious. It doesn't answer the question (THE question) as to whether the contestant (who obviously doesn't know what was behind the door he first picked) would,or would not, be better to swap!Actually it can be explained very clearly, in a way which is simple, and intuitive. I won't spoil the fun for anybody who hasn't tried the puzzle, so if you haven't, don't decipher this:
Personally I'd suggest Googling for an online translator where you paste in your block of text.For the lazy amongst thsoe who can't be bothered to do it in their heads, try the following
Did you mean ANSI?(in BASIC, since that's probably the most universally-undesrood language, but it can easily be adapted to ansy other language.
So it tells him the probability of it being better to swap, and the probability of it not being better, and one of those numbers is larger than the other, and that doesn't tell him whether it is better to swap or not swap?What you have written (in code) is surely just a statement of the obvious. It doesn't answer the question (THE question) as to whether the contestant (who obviously doesn't know what was behind the door he first picked) would,or would not, be better to swap!
I confess that I did that first (just like ebee and EFLI), but thought I'd then have five minutes of funPersonally I'd suggest Googling for an online translator where you paste in your block of text.
No, I didn't. You know what I meantDid you mean ANSI?(in BASIC, since that's probably the most universally-undesrood language, but it can easily be adapted to ansy other language.![]()
