Interesting thought, although I think that would be much more probable in a modern CU with DIN-rail-mounted MCBs, in contact with one another. Those plug-in Wylex MXBs usually have significant air gaps between them, so I would imagine that one would have to get extremely hot before it would cause the adjacent one to operate. However, who knows?! EFLI's idea about two ring final sockets circuits being cross-connected, and some intermittent fault (goodness knows what) being on just one of them, sounds perhaps a more likely explanation for simultaneous operation of both devices. ...Are these two breakers that trip adjacent to each other?? ... One circuit may have a genuine fault and the MCB may be getting hot and causing the other one to heat up and trip out even though there may be no failure on that MCB's circuit.
mack10: If you switch off just one of those two MCBs, does the corresponding circuit lose its power, or do you have to switch both MCBs off for either circuit to lose power?
Possibly, although it seems very odd that it's happened more than once today, but hasn't happened during the previous many years.My educated guess is that the kitchen circuit got overloaded at Sunday lunch time (cooker / washer/ kettle/ ??) and tripped the adjacent breaker.
