I don't think there was anything novel about BAS's or my interpretations - ours is much the same as everyone else's, but we didn't express ourselves very clearly.Yes, I think you'll find that's what I said above. And I don't even have a green book. ... It probably does, but neither of you said that. ... Maybe, maybe not. I was only concerned with novel interpretations of well established rules.
However, I think you may have missed the main point I was trying to make - probably because, again, I did not express myself very clearly. I was talking about "100mm and a bit" partitions - which are, of course, too 'thick' for the part of 522.6.101(v) we are discussing to apply. As I said, particularly if (as is common) the cable enters the partition at about its midpoint from the void above, how can one be sure that none of the cable is within 50mm of the 'non-accessory side' (where, with a wall that thick, there is no safe zone created by the accessory on the other side).
