- Joined
- 31 Aug 2013
- Messages
- 261
- Reaction score
- 1
- Country
Hi everyone,
Just wanted to get a heads up on what I have planned for this basement wall.
The wall in the picture is a party wall not an earth retaining wall, in fact despite having a basement none of the walls are earth retaining. The earth is retained in the garden with another wall.
Now I am intending to use cement, sika waterproofer and sharp sand and render this wall. I then intend to paint on something called a cementone aquaprufe, which is a cold applied bitumen to the wall, and then finally dot and dab standard 12.5mm plasterboard to the wall, and then skim with finishing plaster.
My question is, is there a maximum thickness I should not exceed when I render with the cement? Will I get cracking? The front section of the basement had been rendered by the previous owners and is 20mm.
There is an opening for the fireplace which I will fix 12.5mm board to and a vent to allow for ventilation. The concrete floor has a DPM in it fortunately.
I just want to make sure I'm doing the right thing if I can have some opinions from you chaps? Thanks
P.S I am going to take more of the lime off the wall before I start because there is still quite a bit on there and may take the ceiling off where it abuts the wall. That pink stuff at the top is the old lime render with horrible pink decorating scheme
