Idiots in every industry I suppose .... it's just that there are those professions where blunders can have unfortunate consequences ... I'm thinking electricians, surgeons, colonic irrigation practitioners and so on
Sure, as you say, there will inevitably be some. However, it would be nice to think that this happened despite generally 'adequate' training, not because of inadequate training.Idiots in every industry I suppose .... it's just that there are those professions where blunders can have unfortunate consequences ... I'm thinking electricians, surgeons, colonic irrigation practitioners and so on
One of the problems, of course, is that, unlike the situation in so many walks of life (certainly surgeons, and countless other trades/professions, but not so sure about colonic irrigators!), electricians are totally unregulated - i.e. they don't have to be 'registered' (or even trained/qualified) in any way to work as an 'electrician'. If there were regulation and 'registration', then with that would presumably come minimum requirements for (and oversight of) the training that was required.
IIRC, we used to have someone here who described himself as not just an electrician but an engineer, who genuinely believed that if you touched a line conductor in which a lot of current was flowing you'd get a worse shock than touching one with no or little current flowing in it.I have had "electricians" asking me why the "safe" neutral they have just disconnected on a live lighting circuit has just severely bitten them...![]()
Would "surgery" of that nature qualify as a valid exemption from the general principle that people cannot lawfully consent to wounding and GBH?Plenty of surgical procedures are carried out by non-doctors. You could operate on your friend (with his consent) on the kitchen table with a rusty spoon without fear of prosecution
It's quite a long time since I wheeled out my classic anecdote - so, for those who haven't heard it before ... an 'electrician' who, on seeing an electric shower in my house which had a pretty long feed from its (RCD-protected) CU, insisted that I needed to have an additional RCD closer to the shower because "even if there were a 30mA fault current at the shower, it would have reduced to far less than 30mA, and hence would not result in RCD operation, by the time it got back to the CU through all that cable"!IIRC, we used to have someone here who described himself as not just an electrician but an engineer, who genuinely believed that if you touched a line conductor in which a lot of current was flowing you'd get a worse shock than touching one with no or little current flowing in it.
I used to know a Senior Lecturer in electrical engineering who was convinced that broadcasters measured the size of their audiences by measuring the current in the transmitting aerial.IIRC, we used to have someone here who described himself as not just an electrician but an engineer, who genuinely believed that if you touched a line conductor in which a lot of current was flowing you'd get a worse shock than touching one with no or little current flowing in it.
Plenty of surgical procedures are carried out by non-doctors. You could operate on your friend (with his consent) on the kitchen table with a rusty spoon without fear of prosecution (don't try it on your dog though, that would be illegal unless you are a registered vet).
The first sentence of what syl says is obvioulsy true. Increasingly numbers of 'legitimate' (e.g. within NHS) surgical procedures are being undertaken by people who are not medically qualified. However, the people who undertake thse procedures are usually very highly trained, in some cases arguably more so (in relation to a limited range of procedures) than medically-qualified surgeons. Famously, 20+ years ago, the John Radcliffe Hospital in Oxford pioneered the use of non-medically-qualified technicians to undertake some parts of heart surgery.Would "surgery" of that nature qualify as a valid exemption from the general principle that people cannot lawfully consent to wounding and GBH?Plenty of surgical procedures are carried out by non-doctors. You could operate on your friend (with his consent) on the kitchen table with a rusty spoon without fear of prosecution
Exactly! He also came out with some other gems, but that one had to take the prize!Brilliant! So if I put in nice long cables, and the current flowing through the loads sort of ebbs away by the time it gets back to the meter, I can save money! Why has this knowledge been kept from me?![]()
