I'm just starting a install of a premier 24 alarm system but cannot trigger the alarm system from the PIR's/
I've only installed two PIR's (as a start) and the walk in test show that these two PIR's are fine.. secure and active wired correctly.. all good so far. When I arm the alarm and wait 30 seconds nothing... I;ve changed the event logs and everything fine, no tamper errors etc.. I'm not sure while activating the alarm if I should be hearing short beeping from the control panel or not.. but either way I stuck...
Any advice much appreciated..
