Is there a regulation on the height light switch's have to be, what's the minimum and maximum allowed, as looking at the rest of the lights, I need one adding and to match the height, theres a stud in the way of it..
Everyone seems to have been talking about the maximum. Approved Document M (which is, AFAIAA, the only source of any numbers and which, as has been said, essentially applies only to new builds) does not distinguish between sockets and switches, and specifies a minimum of 450 mm and a maximum of 1200 mm from finished floor level. Although the text isn't explicit about this, the diagram provided shows switches and sockets wholly contained within that 450 - 1200 mm range, suggesting that the bottom of a switch should be above 450 mm and the top of the switch below 1200 mm.
I have to say that I would have thought that anyone who wasn't in a wheelchair would find light switches anything like as low as 450 mm to be extremely inconvenient. Indeed, as my back gradually shows the signs of the progression of the decades, I think I would personally find it potentially quite difficult/painful. In fact, I'm not at all convinced that 450 mm would be very good for those in wheelchairs, either - I suspect that something approaching 1000 mm would probably be best for them.
