Hi guys, this is my first post and might be a bit of a long one, but I am really hoping someone can help me out.
My girlfriend and I have bought our first house which is solid brick wall construction, Victorian with sash windows. All is fine, except in the dining room/Kitchen (they are joined, open plan) I have noticed that recently it feels almost damp. The only way I can tell is that bits of paper that we have left in the room have gone a bit soft and wrinkly. Also I left some rock salt out in a pot by accident and then noticed a few days later the salt was wet, like it had drawn moisture out of the room. I have been considering using something like Kingspan internal insulation plaster board in the kitchen and dining room anyway to make it a bit warmer (its end of terrace and dining room/kitchen are the end rooms) but will this also help keep the room less moist? I assume when using this plasterboard you need to do the whole room and cannot just do specific walls as otherwise you just force the condensation to the cold walls that have not been insulated?
The flooring is on joists with air bricks supplying fresh air under the floor (if this makes a difference)
The other option potentially is that we have an old fire place that has been bricked up, so I am considering bringing this back to life, would doing this reduce the moisture in the room (when the fire is on?, but may not be much help when it’s out?)
The only other point to note, is that in kitchen/dining room the only source of heating we have is one radiator, that is currently not working. We are going to get the radiator fixed, plus potentially install another radiator, so will this reduce the moisture content in the room? Also, we are looking at changing a very cheap nasty laminate floor to a engineered board which should be better insulated which might bring the room temperature up.
Guys – any help/suggestions would be really great!
Chris
Chris
