Power Cut last night now central heating doesn't work!
9 Sep 2010
London
Last night had a power cut ( while the central heating was on ). Today there are no lights on the pump ALPHA2 L ( only 8 months old ). I also thought i heard 4 loud bumps this morning but i was half awake so either it came from the pump or the neighbour!
Also the boiler ( greenstar RI ) won't light up, guessing this is because the pump won't start
Tried switching the mains off and back on again. Also opened up the box next to the pump and inside there is a fuse ( F2AL250V ) which looks fine but i cannot test it
Anyone got any idea's what i can do to fix myself before i call BG
Doing a quick search heard people talking about doing a reset?
Thanks!
Firstly, some questions to help find problem.
Is boiler blue light on, is the programmer asking for heat (lights on).
Also, are you on BG contract, if so, call them, you are paying for that
cover, let them help you
Yes the boiler blue light is on and the programmer lights are on
thanks for the reply
OK,
I see from previous posts you have a mid position valve, do you have the equipment or knowledge to test for voltages at the system junction box
OK,
Nope
And yes i am on homecare 200 but it doesn't cover Home electrics just boiler / control and central heating. Also i guess i am best not mentioning the power cut?
shouldn't matter about power cut, your heating isn't working and they will fix it. It all depends on whether the mid pos vale is sending power onto the boiler or not, if it is, the fault then lies at the boiler. If it isn't, then the system controls are the fault. Either way, BG will sort it.
ok many thanks for your time
Was this an area power cut?
It does sound as if there is a fault which would be unusual unless there was a surge and the boiler has been damaged.
Assuming you have turned the room stat up and pressed the button on the boiler to reset it and still no result then call out BG.
Tony
Tony
Yes power cut in the whole area. I phoned a friend and he to had the same power cut and he lives nearly 2 miles away
Reset button the boiler? Can't see one on my boiler
I think you press the blue light for several seconds.
i haven't tested to see if it heat up the water. Regarding the reset, i cannot see reset button, blue light
A reset fault condition will exist if the electrical power to the boiler has been interrupted.
To reset the boiler:
Turn the Central heating temperature knob anticlockwise to the “RESET” position and hold for approximately five seconds and then turn the knob back to the original temperature setting.
MANY THANKS! that sorted it...working perfectly now
Thanks again for your time and great advice
Cheers
