- Joined
- 21 Sep 2011
- Messages
- 4,843
- Reaction score
- 1,172
- Country
No point in tampering with the stat position or setting then.
Even if you have the balance way out some of the rooms would be baking hot.
It make me wonder if the boiler is big enough or set correctly for the size of house, assuming the insulation is reasonable, eg; D Glazing and loft insulation.
It really needs a Gas safe engineer to check the gas rate / pressure and give an opinion on the boiler size, which is not a DIY job as you can imagine.
Unless I have missed it you don't say how old the boiler is.
If it is an old boiler it might even have been installed for partial heating very common in the 60's just rads downstairs, then people add more rads or extensions.
