L
leeweedon
Hello,
Just want to fly this up the flag pole and see what mistakes i've may be making in the planing.
I currently have a broken security light (it's weather worn and presumably fkct) It is connected via 3m T+E that goes down and then though the wall in to the house. This joins to a single fused switch. This connects to its only MCB in the CU. There is nothing else on the circuit.
I plan to Remove the old light and replace it with 2x "Pro Twin PIR Spotlight Graphite Sensor Controlled 2 x 42W"
As I prefer having channeling on the side of the house instead of plain cable being 'tak'd' I'll house 2x runs (one to each light) of T&E (1.5m) in some 20mm plastic rigid trunking.
The cable will go in to the house through the same hole where I want to have a dual switch (one for each light) and then on to the CU.
My initial thought are I need a fused switch for this, but would that be over kill?
Any help is greatly appreciated.
Lee
Lee
