Good morning all,
We have a combi boiler CH and HW system in our house, and everything seems to work fine. We get hot water and heating, but the pressure on the boiler, despite being topped up numerous times keeps dropping from 1 bar (manufacturers recommended pressure) to 0 (it takes about an hour and a half to drop).
Some general info;
We moved in about ten months ago and the boiler was already plumbed in. I top it up using the induction loop which is constantly attached to the boiler. As far as I can tell we have no leaks on any of the visible pipes (some of the pipes run under a concrete floor so can't check everything).
We have installed a new radiator last week, but the pressure was dropping before this was installed. Also, not sure if relevant but I noticed whilst bleeing the radiators that one of the insert plugs for the bleed valve doesn't tighten - so that when you use a bleed key to open the valve, the metal insert just keeps spinning round until you use some pliers.
My question is, whilst the system is working should I be worried about the fact there is no pressure? Are there any obvious things I can look at before calling out a plumber (the house is costing us a fortune at the moment and with Christmas coming I would much rather leave things if possible).
thank you for any help, I am slowly falling into despair with this house!
N.
Some general info;
N.
