This is my first post here so apologies if it is in the wrong section.
I have recently moved into a new house (new for me, house was build at the end of the 50's).
I have an issue with my heating/programmer/boiler.
If the programmer is only calling for heat then the boiler runs fine, everything gets hot etc...
But, as soon as the programmer calls for hot water then the boiler goes off. I have my heating set to continuous and have had to resort to using the immersion heater for my hot water otherwise it won't get hot.
If I turn the heating off at the programmer and turn hot water on then the boiler runs fine again.
It is a Kingshield T62 programmer and I have 1 3 port mid position valve.
As far as I am aware the valves, central heating pump, HW cylinder etc were all replaced about 4 years ago after the previous owners had an electrical fire in the upstairs bedroom.
Any help in sorting this issue out will be gratefully received.
