Home buyers report said "The concrete lintel over the rear patio door is too short. Further investigation is needed. Condition rating 2."
Here are some pictures:
Small gap at the left, close up here:
There's also a crack above it:
My uncle is a civil engineer and said "If the window still opens and closes without binding then nothing has moved and is unlikely to move in the next few years."
Regarding the cracking the home buyers report says "As far as can be seen from this single inspection the movement seems to be non progressive."
Is this safe? Does it need fixing immediately?
The surveyor said it was "Condition rating 2.", which he describes as "Defects that need repairing or replacing but are not considered to be either serious or urgent. The property must be maintained in the normal way."
Any advice is greatly appreciated.
Thank you
Thank you
