How much energy down a 32mm pipe?
10 Feb 2007
Cumbria
How many BTU or KW's of heated water can be realistically pumped down a 32mm pipe using a conventional heating circulator?
Distance of 50m
Not much, 32mm is a cold mains pipe size. Perhaps you mean 35mm in which case lots. I've used it for 40kW and 42mm if much over that. You'll need a bigger circulator though.
Thats 32mm ID
depends on the tempreture drop required across flow & return
Is this Uponor econoflex?
No, Uponor too pricey
http://www.polypipe.co.uk/building-...olutions/pre-insulated-piping-systems[/QUOTE]
38kw. Will be just outside the limits of a domestic circulator though.
That's a big 45 kw oil boiler I installed on a 20m run off 32ID uponor a few years back.
Big circulator though!
