I have a unvented "system boiler" type heating with pumped water and heating (separately controllable). The main controller is on the first floor in the airing cupboard. I have looked into moving it to the downstairs utility room but the cost is proving to be prohibitive due to the flooring and wires required to effect the move.
I like to keep the heating on fairly stingy twice on/off settings and then press the boost button to give an extra hour of heat if it gets chilly. Its a real pain to have to go upstairs to do this (dark cupboard and generally too lazy
). I am only concerned with the heating side from this point of view - the hot water can be fixed to two on/off's per day and I rarely want to boost this.
I have considered the following as a solution:
In the hall downstairs I have a simple mechanical 2 wire room thermostat. I was thinking that if I got a programmable room thermostat with a boost button then I could install this in its place. I could then set it as normal with twice daily on/off's. I could then put the heating on "constant" on the upstairs timer (leaving the water on twice daily as before) and effectively use the room thermostat to control the heating part of the system from downstairs.
Is this a sensible plan? Are there any ramifications to doing it this way?
Paul
Paul
