I have got few years old Baxi combi 105HE. As such there is no problem with hot water and the heating, so far they seems working fine. Initially when you use the tap for the hot water, the Tap and the burner LED's comes on the combi and they go off when nobody using the hot water, but for last few days the Tap LED is continuously on and it seems the fan and pump are not cutting out which it use to be. (see the picture) There are no flashing fault lights. The temperature lights all come on in sequence up to 80 degrees. The Central heating works perfectly. PRE-Heat is turned off.
Any advice please?
Any advice please?
