three core and earth cable between the two way switches Rea
12 Dec 2013
Ayrshire
I found the three core and earth cable between the two way switches
had the blue wire inducing a voltage onto the yellow (outermost wire) which
was then producing a current to neutral via the LED lamp, which dimly glowed.
Other lamps would have enough resistance to block this.
I ran in another cable to replace the yellow two way strapper
physically separated from the original three core.
You may have found that the cps was not earthed. I have found this can cause problems if there is not a proper earth.
Or install a snubber. Easier than a separate cable.
