Hey,
I'm designing my bathroom refit. The layout in the design at the moment puts the sink on the opposite wall to where the external stack is, so I thought about taking the sink waste straight down, and through 2 joists where it will boss in to the internal part of the toilet waste.
In the attached image, the red circle is where the toilet currently is, with the pan connector dropping straight down under the floor, so the stack actually enters the house under floor already. As you'll see, the design extends the stack to the opposite wall to where it enters the house.
View media item 70688
Unfortunately the bath needs to go where it is in the design, because at the moment it's where the toilet and sink are in the new design, but due to width constraints I can only get a <700mm bath in, and I want 750mm at least.
Alternatively I could get a pan connector that has a boss on it, but I'd need an open backed toilet for that. This is the one I currently had in mind, which wouldn't work with a bossed pan connector.
http://www.betterbathrooms.com/toilets/calder-toilet-and-seat/
