Hi, we have a Greenstar Utility 18/25 oil boiler which we believe is a fully pumped heating system. We have an unvented cylinder upstairs (think this is hot water only?) There is a pump in the airing cupboard. The heating comes on and off ok but the boiler does not seem to stay on for more than about 5 minutes. Sometimes the rads get very hot, other times just warm.
The Honeywell CM927 is calling for heating and the green light on the relay box is on. The boiler comes on as does the pump and they both stay on for about 5 minutes. The boiler turns off after about 5 minutes despite the maximum temperature not having been achieved. When the boiler turns off so does the pump. The Honeywell controller is still calling for heat and the relay light is still on.
Should the pump still be running when the boiler switches itself off, so that the heat is still pushed round the system?
We have replaced the Honeywell controller and am wondering if the installer settings are incorrect. We have changed the cycle/hour and minimum on times as per the recommended installer settings for an oil boiler. However there is also a setting for pump exercise and heat/cool change which are both disabled but I don't know what they are or if they should be enabled?
So far we have had the pump replaced and the boiler thermostat to try and remedy this ongoing issue but it hasn't solved it.
Any advice greatly appreciated. Thanks for reading.
