I assume they mean within the backbox of the outlet!Curious why you want to use a choc bloc within a socket.
Likely the reason why the OP did not over elaborate.This invariably leads to a plethora of 'yes you can' or no you can't' responses.![]()
So why would this be done?
*If the cables are too short, it will help extend them. Is often required when changing socket plates, as the terminals could be in differing positions to the ones of the outlet that has been replaced or if you wish to move the socket positioning a few cms, if the existing cable lengths are not suitable or if someone has accidentally cut the conductors too shortor they are broken/damaged.
*Also you can use them to alter the circuit configuration, if altering/extending the circuit. It is better done in a safe accessible space and the backbox meets that criteria.
Other reasons could be the safe termination of disconnected redundant cable or the termination of a cable that is to be connected at a later date.
But you could if possible, pull the existing cables back and make the MF joints within a ceiling/floor void and extend back up to outlet with continuous cables, then no need to render in a joint.
Or just install new cables to extend and have no joints!
