Hi guys,
Another boring downlight question for you.
I’ve got a large extension (8x3m) which I’ve completely gutted in order to convert it into a Kitchen/Dining Room.
I’ve installed all of the sockets, external lights, and 2 main lights but we’re wanting to add Downlights to the mix.
My question is what is the best way to wire these in and which downlights are the best to go for (240v or Low Energy)? We’ve got 10 downlights in total to fit and I’m a little concerned that the lighting circuit might not take it.
Also, I’ve been reading conflicting information on the net which says they must be connected to the Lighting Circuit and then others saying they should be connected to the Ring Main via a FCU. So which one is correct?
Although I’m quite competent on the Electronics side of things and I regularly build circuit boards, this is something completely different..... although the same If that makes sense.
Just want to make sure it’s right.
Cheers.
P.S. I know they need to be wired in Parallel.![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers.
