This is a little unusual for me and just wanted to hear out a few other more experienced builders than myself before attempting this.
I've got a 5.4m opening to create in a 9" brick wall. Haven't chipped off the render yet to see if the mortar is decent or not so cant tell you that yet.
Here's a pic
The red rectangle is where the beam must go. The grey area edged in orange is a section of brickwork I COULD remove as there will be a second storey extension going here. Ideally I don't want to take it out until I need to for weathering reasons etc.
The issues I can see are that there's no triangle of brickwork to support, just a whole section of wall and roof. Furthermore, I want to fit the beam at floor joist level (beam runs parallel to joists so can sit next to the last one). Lastly, this beam is going to weigh an absolute ton meaning man handling it into position will need a team of burly blokes and fairly decent access. Is there any type of equipment that's recommended to lift the beam?
I was planning on positioning Acros either side at 900 centres and needling the wall above. I've got a bunch of Strongboy props but thought that perhaps these wouldn't be man enough for this particular task.
Any thoughts on best approach would be much appreciated.
Here's a pic
