Hi there,
I've been trying to find out (and failing) how to support an external wall whilst steel beam is being installed. I've already replaced 2 internal supporting walls where the floor joists run across the walls This was done using scaffold boards and acros.
I have a steel I-beam with a plate welded to the bottom to span the cavity and sit the external brick work on (drawn up by a Structural engineer). The steel is being installed directly below ceiling level (to be bolted to the two beams that are replacing the internal walls) therefore I don't have space internally to insert needles through the wall to be picked up by acros internally. How does this work? All of the sites that I've found information on, are talking about supporting the wall on both sides under the needles, which I can't do. Has anyone done this and can offer some words of wisdom? It would be much appreciated.
Thanks,
Carl
Thanks,
Carl
