Reducing Presure
8 Jun 2012
Buckinghamshire
HELP
I have put to much pressure in my Worcester Bosch 28i Junior boiler, its way above 3 pressure went not firing how do i get the pressure down
B
Bleed your radiators...
and take water out yes ?
Yes, pressure in your system is just the amount of water, so too much pressure is too much water, and not enough pressure is not enough water. If you bleed a radiator and allow a small amount of water out each time you will eventually get it down to a suitable pressure. Usually between 1 and 1.5 is ideal.
Piers
Piers
ahh right
Do i bleed each rad or can just reduce the pressure by bleeding one
Piers
ahh right
Just one will do the job... the pressure is the water in the entire system so if you take some out it will reduce it on the entire system.
