hi everyone
Fernox F3 has been circulating in the central heating system for a couple of weeks now, and as well as it clearing the blockage in my boiler/diverter valve I've noticed it has made the boiler operate very quietly, its as quiet as some brand new boilers i've observed, so really impressed.
I have the MagnaClean installed on the return pipe and cleaned it recently. So I do have a device to catch the sludge, however, reading posts on this forum I understand that the system should still be thoroughly flushed through right?
my question is I live in a bungalow so all radiators on one floor, and the combo boiler is in loft. only one radiator has a drain valve, its close to the bathroom.
now if i use that drain valve it won't even half empty the CH system right? because all the rads are on the same level?
i was thinking of just emptying as much as i can through that valve, then refilling and bleeding. and then let CH run for a few days again, then drain and refill again as before, let it run again for few days, and keep repeating, until eventually the water is very clear. then add inhibitor and forget about it.
will this method work ok? i don't want to try any messy method as had new carpets etc put in, so don't think the mrs would be happy if i got sludge splattered on walls and floor etc.
thanks
Ishaq
thanks
Ishaq
