Engineered wood flooring - finishing around stairs etc?
10 Feb 2014
Wiltshire
I'm soon going to be laying engineered wood flooring throughout most of our downstairs including living room, hall and dining room (standard click-lock planks) - I've laid similar in my previous home but in a simpler room and just used beading around the skirting to cover the gap.
This time I'll be removing all the skirting boards and refitting to get a better finish than adding beading, but I'm not sure how best to handle where the floor will meet the bottom of the stairs and our French doors - I'm guessing I probably just need to use some sort of joining strip?
I've added some pics below to show where I mean (the stairs will be carpeted).
Thanks for any help or advice!
The stair carpet will cover any gap there so shouldn't be a problem, well it certainly does in my place :0
I figured that might be the case - but I'm still unsure about the stair post - is it ok to cut a small section out for the flooring to tuck under or would this be a complete no-no?!
I wouldn't cut into the post. Leave a small, even gap, and buy some flooring silicone, they do loads of colours to match most wood colours.
Thanks, that makes sense - would you suggest doing the same thing for the threshold of the French doors?
For the french doors, I would remove that sill, and go right up to the door (-10mm), and then fit either a small wooden or plastic strip over the top.
For the doors, lift the plinth and cut a lip out that can over lap the new floor and allow for expansion, or remove completely and fit a floor fixing square edge profile a cross the area.
