I've had a search, and can't find anything that exactly answers what I'm trying to do, at least not with the same wires.
I'm trying to wire up a double light switch for my ceiling light, and wall light. Both lights are only controlled by one switch. The old switch was a dimmer, I'm not sure if this makes a difference?
I have attached a picture which shows the old switch and how it was wired. It has L1, L2 and com.
The new switch has L1, L2, and L (L being the equivalent of com?)
I wired it up (or so I thought!) exactly the same as the old one, and neither light works. I then followed the wiring diagram provided, and can only get one of the lights to work (I did swap the wires around, so I know both lights actually work).
The wire on the left in the picture is red, blue, yellow and earth, the wire on the right has red, black and earth. The black and blue wires were joined together as you can see in the picture. There is a red bridging wire from L2 to com.
Could anyone please give me any advice as to what wires should go where? Any help would be gratefully received!
