In connection with the requirement to replace some supply side plumbing, it will be necessary to shut off main stopcock (outside).
Thames Water indicate that it is the property owners responsibility to open/close the stopcock.
Stupid question perhaps but does the sort of cover as in the image lock on, or does it simply lift using a couple of prybars?
Asking because there are two key holes, had a quick go with one prybar and nothing moved although that may also be because the covers fit rather well in the frame/surround, and any gap fills up with dirt.
Thanks as usual.
Thanks as usual.
