flexi straight on to iso valve
yes you can...you may find however that it may be difficult to get a perfect seal because the isolator has tapered edges to accept an olive....this gives less of a flat surface to grip the rubber washer in the flexi.
Do keep an eye on it for a while!
John :)
Yes, but not ideal. The end of the valve will be slightly tapered to accommodate the olive and this can cut into the flexi washer.
:roll: Great minds and all that :)
A better method - if you want to use a flexi - is to have a stub of copper pipe just after the isolator, and use a flexi that has a compression end on it.
I tried your method ages ago with some Ikea taps with flexi connectors....all was initially fine until the tiny droplet two days later!
John :)
No problem, just file a flat face on the edge the washer is going to sit on. Although you've probably done it by now :wink:
John :)
If the valve is chrome, why not screw one of these on, giving you a flat surface for the washer?
http://www.plumbnation.co.uk/site/stelrad-extension-pieces/?gclid=COCgqq2r470CFbLItAod3wMADA#
Although, depending on location and visibility, it might look a bit daft
