Afternoon all, don't you just hate easter, all those adverts advising it's a great weekend to finish/start your next DIY project........ well i decided to try and finish some lighting so i could continue painting into the late hours but ive hit a problem......
I need some help/advice on a bathroom wiring circuit,
We moved into a house and the bathroom needed gutting and re plastering, to make safe for the plasterer i disconnected the downlights and pull cord and shaving socket.
The bathroom previously had 5 x GU10 Down Lights fitted and they were wired in a spider like format,
All the plastering is done now and i am trying to reinstate what was i previously undone however i am hitting a problem, i have decided to only fit four bathroom downlights and reconnected everything in what i believe to be the same manner as it was before and disconnected the spare legs of wiring which no longer go to a downlight.
Now when the power is turned back on the lights are very dim. NB: I have swapped out the old D/L for new ones and fitted them with LED GU10 bulbs this hasn't posed a problem anywhere else in the house where i have done it,
I have done a crude sketch of the wiring as it currently stands and could do with some advice/pointers as to where i may have gone wrong,
Thank you,
Thank you,
