Yes yes, but what is ID?
Yes. I am completely serious.Are you serious on the content of your last post?
Actually, if you are going to quote rules, you would do well to get them right - which you haven't in this case.When an ID situation has been identified the appliance must be CAPPED off and disabled from further use until the situation is rectified and passed as safe to use by a RGI Registered Gas Installer.
Are you sure on the above and still serious of your previous comments?Actually, if you are going to quote rules, you would do well to get them right - which you haven't in this case.
Yes and yes.Are you sure on the above and still serious of your previous comments?Actually, if you are going to quote rules, you would do well to get them right - which you haven't in this case.
Did I say otherwise ? No. So relevance ?GIUSP 7.1 states 'products of combustion leaking into buildings including flues terminating into loft space'.....
ID/RIDDOR.
Dos not matter whether appliance is used on a regular basis or not.
Have you heard an expression about casting stones ? You made a false statement (typical of those in the gas industry, and not unlike some of the false statements made by trade bodies/their members in other trades), I've picked you up on it, and rather than justify your statement you then start throwing stones.Of course SimonH2 is aware all these as reflected in his posts of late. Bless![]()
Disclaimer: I'm not a professional spark, I'm not a professional plumber. Just a keen amateur.
The latter is what you admit to a “keen” amateur and nothing wrong with that per say. sorry but you are putting yourself in the same category as your installers with that aggressive manner of your last post, which is a shame seeing as I thought you were of the discerning type. As “keen” amateur you should listen to others more qualified who give you sound advice and be glad of it that I assume is why you put the post up in the first place. I am a professional gas fitter registered with Gas Safe also I have a GS ticket for gas fires and you are totally wrong in your stance. I am going to give you good advice take heed or not as your will.
You have no perception of what products of combustion are and the effects of their release into the near environment from their source especially when confined within a space.
If the fire in question was used in the situation you have described with corroboration of the added photos, even for a short time the potentiality of a serious incident occurring is very high. Believe it or not it can take a minimum of one to three minutes to die in the wrong conditions with a blood saturation of 85-95%.
One thing is clear you do not understand the workings of a flue, more importantly the composition of products of combustion in relation to the burning of any fossil fuel. The reasons you put forward for safety are totally preposterous and I think you ought to stand back and dwell upon your misguided comments for a while.
I doubt whether you have heard of Vitiation, down draught, passive ventilation and advantageous air, a few for starters.
Do you know what the safe level of ventilation is required for the safe evacuation of products of combustion in any confined roof space in relation to; the ratio of square area to ventilation allowance of said roof space, making allowance for the Kw output of any open flued fire when operating “without” the aid of an open flue of the correct diameter evacuating said fumes to the atmosphere?
Answer; I will save you the bother of a more stupid, embarrassing and death defying reply, in short NONE.
The fact that you think that gas cannot make its way through minor gaps and cracks’ including plaster board is astonishing. To help you with this you will of course have to look at the recognised allowance percentage of advantages air per Kw in a room /dwelling before any ventilation is required in normal situations. That should tell you something about the relationship of gases and travel of gases through gaps however small.
Oh and do you have the ability to control someone’s actions in your absence not to leave a gas fire on 24/7 when the weather gets cold and the boiler packs up. Happened before in same property remember, boiler packing up that is, the rest I doubt if we will ever know.
If you want some more sound advice on flueless gas fires I suggest you be a little bit more tolerant in replies because you might not like what you are going to hear on the assumption of your attitude to your previous flue installations. Also change your gas fitter.
PS. I would also change your disclaimer to get a little more credibility but alas it may be too late.
As you are so certain, you'll have no problem showing everyone where the law states that "When an ID situation has been identified the appliance must be CAPPED off and disabled from further use until the situation is rectified and passed as safe to use by a RGI Registered Gas Installer."
No I won’t have a problem with the above that's for sure...(a later post I fear). If I met such an arrogant Land lord as yourself in such a situation I would ask you for the appliance to be capped off with your graceful permission of course.
If you refused, then no problem, your area gas network supplier would visit within 2 - 4 hours of my phone call and ask for entry to cap the meter off, I might add it will be the meter that is capped off which includes the whole premises not the appliance. Refuse them? They have a statutory right to enter your property to do same.
Refuse that, especially with aggression? No problem, your area network gang with Kango etc will dig up the road and cap you off there, they won’t ask they just start. There is more, which I will leave for you to contemplate anyone allow it to get that far and beyond.
The last time an ass hole tried to be big time with the legislation which I was the starting point (a humble gas fitter) and put others lives at risk, the aforementioned was put in place, Reconnection to the gas supply in the road, as advised by Transco, as it was then, estimated a cost L/L £ 8800.00 (main road you see) to reinstate the road let alone further ongoing costs. The l/l at that point saw sense.
So live on in your dream world of putting other people’s lives at risk. Just to add, ID means just that the rest of the procedure just follows, everyone knows how to conduct such a situation........ it will be you who is new to it.
I wondered how long it would be before you played the "I'm qualified, treat my words as the word of God" cardI am a professional gas fitter registered with Gas Safe also I have a GS ticket for gas fires ...
Wrong. I do have a good idea. Do you want a discussion of how CO bonds with the haemoglobin in blood with a higher affinity than CO2, hence why it is so toxic - it accumulates and depletes the ability of the blood to carry oxygen. That's the primary risk. And no, I didn't have to look a word of that up.You have no perception of what products of combustion are and the effects of their release into the near environment from their source especially when confined within a space.
Wrong again. Though it's a loooong time since I forgot the maths behind it.One thing is clear you do not understand the workings of a flue ...
Just because I'm prepared to consider the various elements involved and actually THINK rather than blindly follow guidance. As I said, half the problem these days is people who can't or won't THINK - they just sheepishly follow a set of guidance with no concept whatsoever of the LEVEL of risk.The reasons you put forward for safety are totally preposterous and I think you ought to stand back and dwell upon your misguided comments for a while.
It might be if I had actually written that - but as I didn't you are just digging yourself into a bigger hole - you know, that hole where you've decided I must be completely wrong and therefore you read into what I write anything that will support that.The fact that you think that gas cannot make its way through minor gaps and cracks’ including plaster board is astonishing.
Again, you are reading into what I wrote something which I never said or implied. You made a statement which is not true. I picked you up on it, you have taken the huff that a "non professional" dare question you as a qualified person and are desperate to find things you can criticise me for.If you want some more sound advice on flueless gas fires I suggest you be a little bit more tolerant in replies because you might not like what you are going to hear on the assumption of your attitude to your previous flue installations.
Interesting, so being GS registered isn't indicative of being competent to work on gas systems then - that seems to be what you are suggesting.Also change your gas fitter.
So that's a "no I can't" then, or you'd have quoted it already.No I won’t have a problem with the above that's for sure...(a later post I fear).As you are so certain, you'll have no problem showing everyone where the law states that "When an ID situation has been identified the appliance must be CAPPED off and disabled from further use until the situation is rectified and passed as safe to use by a RGI Registered Gas Installer."
What, you mean you don't have the legal right to do it there and then like you implied you did ?If I met such an arrogant Land lord as yourself in such a situation I would ask you for the appliance to be capped off with your graceful permission of course.
Which I didn't, and wouldn't - that's just your imagination.If you refused
Again, stop with the accusations of things I have not said or done. I don't suppose you'll be prepared to apologise for it though.So live on in your dream world of putting other people’s lives at risk.
No, it's not new to me. That's only in your imagination.Just to add, ID means just that the rest of the procedure just follows, everyone knows how to conduct such a situation........ it will be you who is new to it.
