But it could occur is you have ever had a dripping hot tap.
Has anyone taken the cold feed off the boiler and ran it to see if the flow drops ? it can be a problem when you have several people look at a boiler as its assumed the basics have been checked by the people before you.
The Tech guy is someone with about 25 years experience the engineer said but the main thing was he isn't time pressured and gets much longer to carry out his appointments.
He's just as clueless as the rest of them though, I mean to not keep bog standard fibre washers in your toolkit![]()
As a result of turning off the water several times and draining down the DHW boiler circuit there's a load of trapped air somewhere in the pipework...that's why the flowrate initially appears higher when you first open a tap and why the boiler flowswitch clicks even when operating the cold taps.
I have no confidence that the basic checks have been done correctly, having looked after 30 or 40 Pumas in hard London water none of them have shown any signs of heat exchanger scaling.
The DHW tubing is the bundle inside the primary water circuit..about 7 meters of 10mm tube AFAIR. If necessary it could probably be descaled with a Powerflushing pump.
It's the responsibilty of the repair eng to bleed out the air..that means running all outlets. Occasionally there may still be trapped air and you have to delve behind washing machines etc. to check for unused outlets or air vents on old dead leg lenghts of pipe (although these should exist if water regs are complied with. Sometimes you find old pipework in airing cupboards and roofs still connected but trapping air.
