Hi, I replaced an honeywell analogue thermostat some years ago with a Danfoss TP75 programmable thermostat. This uses 2 batteries and has just two of the three wires connected, 'common' plus 'heat on'. Making the connection requests my system to call for hot water to be pumped to the rads. Simples.
Is there is a smart energy system, e.g. nest/tado etc that can simply replace this programmer with one connected to wifi and has a smart phone app?? That simply creates a circuit when heat is required (by app or programmed timer or manual room temp adjust).
Or do I need to build one myself from a Raspberry Pi?
Any help appreciated.
NB. The blue wire in the diagram is not connected.
