- Joined
- 27 Oct 2013
- Messages
- 218
- Reaction score
- 10
- Country
Hi everyone,
Currently renovating a 2 bed bungalow (which has an unused loft conversion also work in progress).
I need to move the existing boiler as part of the loft works (flu issues) and as the current pipework is ok but not as I would like it I want to make changes while I have the opportunity.
The 2 attached diagrams show the current and propsed layouts. As well as the new boiler position, there will be a new additonal radiator under a large bay window (north facing) and the radiator in the dining area will move to the adjacent wall (so the french doors can go in).
There will also be 2 smaller radiators in the hallway rather than one big one by the front door. This will give some heat in the hallway allowing heat to rise where the new stairs will go.
Main concern is all the radiators are fed on 8mm copper tails from 15mm runs dropper from a short run of 22 from the boiler. I also want to replace all the existing rads as they are all very old and rusty / damaged for the most part.
Would much appreciate feedback / recommendations. The bungalow has cavity wall insulation but the roof space has very little at present. When I complete the loft conversion it will be fully insulated sub floor and under the roof rafters.
Cheers !
Some of the existing pipework ! Not done by me !
Cheers !
