I'm going to replace and update my central heating radiators.
Ideally they will be approximate the same width and height to suit existing flow and return pipes.
I have used an online BTU calculator for each room to determine what I need.
I will be fitting TRVs throughout.
If I fit the same size as existing and use a type22 double panel double fin radiator its BTU is higher than those older radiators fitted.
Question:
If I fit a Type 22 radiator and throttle it down with the TRV, does this present any problems.
What I want to avoid is a radiator that does not warm the room up in very cold weather and obviously don't want to fit a lesser performance radiator and find that the room does not come up to temperature.
Also...I don't want the boiler to continue to heat lower performance radiators; hence using more gas and more expense.
I would appreciate some expert advice; Thank you.
Question:
