12kw MINIMUM is no use - ( unless maybe your house doenst have a roof or walls then the heat loss calcs might add up.
To the OP - Do a proper heat loss calc for your house before looking at what boiler you want.
As Dan says, you need commercial for it, LLH - Big Pump and it will turn its self on and off till the death of it. It doesnt light at 12kw. it probably ignites about 30-35kw and holds there for a minute, by which time it will be due to shut off on a severly undersized system
Where a 24kw boiler could heat the place probably no bother and can rate down to 4 or 5kw to maintain that heat (and will still have to shut off and cycle at that)
I doubt you have read all the thread to write misleading advise. Initially this Dan fellow, backed by others, including you, wrote that the boiler was "too big" and would continually cycle on an off. I looked and found it can
run down to around 12 kilowatts, so was not too big at all and would not continuously cycle on and off. The OP already has a 28mm gas supply, so no problems there. Then this Dan starts to try and justify his mistake - or more likely defend his wind up of the OP.
I directed the OP to another thread where I fitted a low loss header and Wilo smart pumps for the heating on a
40 kilowatt boiler. It works brilliantly and has been operating for 6 months perfectly giving a wonderful even heat through the house. The OP can also fit a fixed speed pump for the hot water cylinder off the low loss header as well. All he needs to do is get a pump for the header that will give the
minimum flow required through the boiler. Being a 12 to 46 kilowatt boiler that will be domestic sized and not cost a fortune.
I have wiped the floor with this Dan fellow, which is not difficult, and many strangely seem to defend when obviously he is wrong, and who resorts to insults when proven wrong.
If I was the OP, I would fit a low-loss header with a pump pumping through it to give a constant flow through the boiler. Off the header have the heating zone(s) using Wilo smart pump(s). Have one fixed speed pump heat up the DHW cylinder off the header. It is best he looks at my post on the Atmos Intergas thread on a guide on how to do it.
Telling the OP to ditch his new perfectly adequate quality boiler to spend around £900-£1,000 on another boiler is grossly irresponsible advise. I did tell the OP to do heat calculations and I am sure the boiler will match his heating requirements. I doubt his 5 bedroom house will need less than 12 kilowatts of heat. His calcs will determine that.
