The Doncaster quote suggests anywhere as long as its not underground.
I somehow doubt any proper experimentation has been done into it's life in a number of different conditions
IMO it does.I imagine that everyone 'recognises' 134.1.1 but it is so vague and subjective that I don't see that it really helps RF with his question.
No it could not, because cable made with uPVC would be unusable. It has to be flexible, therefore it has to have plasticisers.Is it the plasticisers which lead to this (supposed?) degradation?
There are many products (without plasticisers) manufactured from PVC intended for use outside - doors, windows, gutters, fascias, pipes etc.
Could it be said that any T+E which does show signs of degradation in a relatively short time was not made very well?
Yes, but is it the plasticiser that leads to the degradation?No it could not, because cable made with uPVC would be unusable. It has to be flexible, therefore it has to have plasticisers.
You and I can speculate, but only he could tell us authoritatively whether or not it helps him.IMO it doesI imagine that everyone 'recognises' 134.1.1 but it is so vague and subjective that I don't see that it really helps RF with his question.
Given that the main feature of the 'degradation' (after many years of exposure to UV and 'the elements') to which you refer appears to be loss of flexibility, I would suspect that it actually results from loss or 'degradation' of the plasticiser, rather than being caused by the presence of plasticiser.Yes, but is it the plasticiser that leads to the degradation?No it could not, because cable made with uPVC would be unusable. It has to be flexible, therefore it has to have plasticisers.
I gave him such evidence. There is a regulation which supports the first electrician's findings.One of the items that has been flagged as an issue are some external lights. They are wired in twin and earth cable clipped to the external stonework of the building, and they are saying the lights need to be rewired ... .am looking for some actual evidence such as regulations which might support the argument either way.
Are we not saying the same thing?Could it be the problem is the the need to have a plasticiser and that some plasticisors are un-stable and over time fail to keep the PVC flexible.I would suspect that it actually results from loss or 'degradation' of the plasticiser, rather than being caused by the presence of plasticiser
Frying pans and fires come to mind. Dramatic loss of flexibility over time (presumably mainly due to environmental factors) is surely the main (serious) problem which has been encountered in electrical installation made out of 'naturally flexible' materials. 'Unnatural' (e.g. silicone) rubbers may be a different matter.Hence the use of naturally flexible materials ( such as rubber ) is to be prefered where the plasticisor is at risk of failure due to the environment.
Indeed. That's a point I usually make when presenting my view that outside use of PVC T+E does not appear to be much of a problem. I'm not aware of any major issues other than those associated with the eventual loss (sometimes) of flexibility - and, as you say, even that is, in practice, seemingly not much of an issue if the installation is such that it can't move.Brittle PVC insulation would not be a serious problem if the cable was securely fixed and unable to move ( or be moved ).
Indeed. My supply, for one, comes via a long run of mural PVC/PVC singles. The only issue which someone might raise is that DNOs appear to usually use (as least, around here) singles which have a black sheath - is it possible that that may mean that there is, say, some UV blocker in there which is not present in 'house wiring' PVC cables?We have been using standard PVC/PVC insulated singles externally as mural wiring since it first came on the market (I've even seen 16mm T&E used for house services), we have not specifically seen any major problems and the amount in use will be in the thousands of kilometres. ... If it was not designed for that use we would have not used it, for financial reasons if nothing else. We expect a minimum life of 50years from overhead equipment so anything that could not achieve this would be a no-no! ... Now T&E will be the same insulation for the sheath so I doubt there is a problem except in the minds of the ultra cautious
anecdotes about T&E which has come to some sort of grief after, say, 5 or 10 (or even 20) years use outside.
