Now you know!
[/URL]
I have seen a sawn-off 6" nail in a plug feeding a 3.5kW immersion.
This the approach that DNO's use when sizing their service cables, Oh an 800amp sub-station fuse will protect a 25sq.mm. service cable off their main, without sub fusing!![]()
Is this a problem? If one looks at the old method of a 15A fuse feeding a 15A socket and plug at the immersion if the 15A plug and socket was damaged finding a replacement at short notice may be hard. Using a nail in a 13A plug would mean still protected by 15A fuse in consumer unit but no fuse to over heat the 13A plug. All fuses produce heat and it is the heat from the 13A fuse in the plug which has always been a problem more so since the plastic bits were added to pins which reduced the heat which could be transferred to the socket. Clearly if no 15A or 16A fuse or MCB feeding socket then a problem. But with fuse or MCB in consumer unit it would be just the same as the aluminium rod I found in fuse holder of Lucas 2TU flasher relay.I have seen a sawn-off 6" nail in a plug feeding a 3.5kW immersion.
Why waterproof, why 16A and why a plug and socket at all?Will a 16amp waterproof Commando type plug and socket be a better bet on an Immersion Heater?
