- Joined
- 22 Aug 2006
- Messages
- 7,591
- Reaction score
- 1,371
- Country
1920's 3 bed mid terrace, SW16, London.
External walls 9" solid
Internals are single brick (masonry block/whatever they used then.)
Wall is between Kitchen and Back room.
Upstairs layout is the same. (ie supporting another single wall, 2.8m high. The roof supports are more on the front/back room division wall, not this one).
1) A common situation so can we rely on a builder's judgment only, or does it need a separate SE to see and specify it? What's the procedure - does/should the builder get a Building Control approval before proceeding?
2) I gather one padstone can go at the the cross hatched area so no pier necessary. What about the other end? Would it likely cover red/blue/green/yellow or need a pier?
3) ££ - ballpark, how much are we talking?? Ground floor, straightforward to access at rear of house. Assuming the steel is to be boxed/plastered as well.
Thanks for any comments.
